RVTRKN
- May 20, 2020
What difference does it make if a company Greasemonkey knows you use Redline lubes? Nothing anywhere can say you have to use a certain brand. I don't use Redline but I am sure it is above the low minimum bar specs that Mopar meets.I changed fluids today and used Mopar fluid for transfer case. But I took a sample of OE and redline MT-LV, I bought a bottle just for a sample. The Redline has a slight red tint which would give it away, that would alert the tech it’s the incorrect fluid, so I won’t be using redline. View attachment 167281
Working at a dealer, we use more BG lubricant than oem in the driveline. Never had an issue in 15 years from non oem fluids.What difference does it make if a company Greasemonkey knows you use Redline lubes? Nothing anywhere can say you have to use a certain brand. I don't use Redline but I am sure it is above the low minimum bar specs that Mopar meets.
On my invoice, after oil and filter change at the dealer, they actually listed Duramax as the oil.Working at a dealer, we use more BG lubricant than oem in the driveline. Never had an issue in 15 years from non oem fluids.
If the transfer case fails under warranty, and the dealer doesn't want to deal with it, on the road for example, thats the perfect opportunity to just say the wrong lube was used that caused failure.
Mobilfluid LT for the 4auto per the manual. Redline MT-LV is a Mobil fluid LT equivalent per their website. Again I recognize it's all opinion and not that one is wrong. Just wanted to share that info.Yup. It's sad but true. All dealers/service reps might not do this but it's possible.
The logic I use is if I can find the specs of what they want and match it up to an even better oil I'll do that. That's why in my front and rear diff I went with AmsOil. As we discussed, can't seem to find exactly what they use in the t-case and trans. Therefore, I just go OEM. IMO, you did the right thing by going OEM on those two.
That's fair. Didn't realize that discrepancy. While I imagine there isn't a difference in one model year I can also understand the hesitation.I have a 2019 and the manual states to only use the Mopar fluid. I also have the part-time t-case. They may have clarified this in later years. Right now though, that's all the manual states. If I get some better clarification next time I have no issue with the Mobilfluid LT. BTW, I'm not the only one with this confusion either. Seems like a lot of folks with 19's can't seem to find exactly what the cross-equivalent is.
Per service info on the 2019 DT tcase fluid recommendations.
2 X 1 quart = $90.00 at dealer vrs $65.00 at parts house, when the oil is crossed to an equivalent then thats what I'll buy, however if it has a red tint I won't. The crossed over equivalent will have to have same color and feel as the OE.
As long as the fluid you use meet the minimum specifications if the OEM fluid, it doesn't matter what color it is. The problem with fluids like Amsoil and Redline is they say it meets or bets the specs but don't actually pay for the certification to make it official.2 X 1 quart = $90.00 at dealer vrs $65.00 at parts house, when the oil is crossed to an equivalent then thats what I'll buy, however if it has a red tint I won't. The crossed over equivalent will have to have same color and feel as the OE.
I just noticed the Valvoline 75W90 gear oil I got for the front diff has Limited slip additive in it. Is that going to be an issue for the front differential?I changed out my front/rear diff and transfer case at 25k miles.
- Valvoline synthetic 75w90 in front
- Valvoline synthetic 75w140 in rear w/ limited-slip (no additional friction modifier added)
- OEM transfer case fluid
Now at 73k miles with no issues.
I just noticed the Valvoline synthetic 75w90 I bought for the front diff already has limited slip additive. Is it ok to use that in the front diff?I changed out my front/rear diff and transfer case at 25k miles.
NoI just noticed the Valvoline 75W90 gear oil I got for the front diff has Limited slip additive in it. Is that going to be an issue for the front differential?
