Ramroo
- Jul 1, 2018
Yes please. BourbonWe can use cases of whiskey? As you can see from my profile pic I'm kinda partial to forty creek.
There you go @Ramroo I fixed that up for you!Yea yea yea
3.92short, fat. Muscular, masculine.
3.21tall and skinnySlender, feminine.
Thanks,
I'm up for that!Thanks,
Just get the bottle.
MIGRANE COMING ON ! LOLThat's not all that accurate because it only works for first gear.
Fat Frank has 4 baskets of eggs with 3 per basket. Slim Sam has 3 baskets of eggs with 4 per basket. Does it matter who you buy your eggs from if you just want 12 eggs?
That explains gear ratios in all gears other than first gear. Axle ratio by itself is meaningless, it's only half the equation. The other half which is just important, is the ratios of the transmission.
Just like 4 * 3 = 12 is the same as 3 * 4 = 12, so it works with transmission gear ratio * rear axle ratio.
When both trucks are in first gear at a stop, yep the 3.92 has the legs to pull harder. But as soon as both trucks are moving, second and beyond, the transmission will downshift to put you at the same-ish RPMs as the other truck; your RPMs will be similar at the same MPH giving you the same torque/hp. Only when stopped or when both trucks are in 8th is there a significant difference.
I prefer to explain gear ratios like this:
You can either have gears:
A, B, C, D, E, F, G, H (3.92)
or
B, C, D, E, F, G, H, I (3.21)
It's not exact, but close enough. Notice how both trucks have a "G" gear ratio; yes that happens in "7th" with the 3.92 and "6th" for the 3.21 but "7th" and "6th" are labels, the actual gear ratio "G" is what matters and both trucks will put you in that gear ratio under the same load and mph.
I kicked around V6 vs V8 when ordering my 2019 as my 2001 has 230 hp.I love my V6. But I’ve never owned the hemi. I test drove it, and drove my brother’s 2019 Laramie with the hemi, but those were limited drives.
I consistently get window sticker MPG. Coincidentally, in a recent trip to Houston, I got to experience long highway drives and plenty of city/highway combo driving. Here are two pictures from that.
The first is after about 1/8 tank or so. I filled up in Denison, TX and took this picture close to downtown Dallas. It was 100% highway. My average and current MPG 24 as advertised.
The second is later that week going around Houston in combo city and highway driving. I took this picture leaving on I45. At that moment I was getting 24 highway and average 21. This is with a little less than half tank left.
Notice also I am going ‘real life’ speeds of 67 to 70 MPH and maintaining 24 MPG.
Most areas around Dallas and Houston are flat with only a few rolling hills and the weather was good. Great conditions for these observations.
Both demonstrate EXACTLY what the window sticker promised and is not uncommon for my truck so far.
Lastly, I do not tow much. I have a 3,500 to 4,000 lb. boat and trailer that I tow infrequently for short trips since the boat mainly stays in a dock. I do a lot of landscaping, so I got the 6’-4” bed. I enjoy great mileage on my daily and other commutes.
Anyway the v6 works well for me, no regrets.
