Have the 12" full screen on and cannot input/type in destination.Do you have the 12” display? If you have the screen split you need to have the NAV screen in full display to get the search function to work.
Unless I pull over. Safety features but what about a passenger if while drivingHave the 12" full screen on and cannot input/type in destination.
What exactly is send and go if you dont mind me asking?Use the send and go on the Uconnect app it works great. Or voice but the send and go works the best
Thanks. Unfortunately my Uconnect app doesn't work.In the uconnect app if you select location you can enter a location by name or address and then send it to your truck it will show up on your screen as a destination regardless of screen you are on.
It’s cool because if you are looking for a place and do not know the address you can enter the name and it will list the places that match starting with the closest to your current location. It’s fast also. Faster than the lock and unlock commands.
Have you tried both apps? There is a guardian app and a uconnect app. If one is acting up I use the other. I have both installed on my phone. Also the send and go should always work. Regardless of the remote features working.Thanks. Unfortunately my Uconnect app doesn't work.
I've tried both apps and Mopar site. They only work after I call Sirius and they send a command or if the truck has been running. Either way, it only works for a short time after then stops working again. I will look into send and go.Have you tried both apps? There is a guardian app and a uconnect app. If one is acting up I use the other. I have both installed on my phone. Also the send and go should always work. Regardless of the remote features working.
Thanks for the info. I'll give it a go.Agreed that voice prompting is the best way to get around the in-motion lockout.
For those who don't know:
1) If you have the Uconnect app, you don't need to have it open or search from within it. You can use Google maps on your phone to search... and then hit the share button and select send-to Uconnect.
2) When Carplay/Android is connected, long press the voice-activation button. This bypasses the in-vehicle nav and establishes a voice link with Google maps.
3) Read the Uconnect nav manual. As mentioned above, once you get the hang of how it works, it's not bad at finding places.
Thanks again.Good luck, MJP. I need to qualify though... my experience is based on nav in a 2018 Durango... but it's version 4C so I assume it behaves like Ram.
Funny that on long trips when searching for rest stops, the in-vehicle nav seems way better at finding those. For everything else, the natural-language capability of Google Maps is way easier to use.
They support Waze tbrough the phone car play options, both android and apple.If u have uconnect without NAV do you just use Siri to get your location? Do these units support Waze?
