Using "4WD Auto" in leu of "4WD High"
Jake1050
My last truck had 2wd, 4wd lock and 4wd low. My new truck adds a new setting "4WD Auto". Is this the go to setting when its just very cold (possible ice) and or wet and the 4WD High is for when on pure snow or packed snow/ice?
What are your determining factors when you are deciding between 4WD High 4WD Auto?
Thanks in advance.
Thanks in advance.
This thread will explain it all…
Yes.
You can make tight turns in 4WD Auto. If you do that in 4HI you will rub rubber.
It's essentially AWD
Thanks in advance.
I only use 4-high when I'm playing around in the snow in parking lots with traction control off, or launching at drag strip. Regular driving on snow/ice/wet is 4-auto.
IF the snow is bad and roads are unplowed yet, 4WD H it is.
If it’s raining and/or roads are plowed and salted, 4WD auto.
Totally agree. I live in the mountains, and when I'm descending along twisty roads in snow packed/icy conditions, even in isolated patches, I wouldn't risk having 4WD Auto switching on/off at the wrong time.
Going up or on flat roads, I do favor 4WD Auto over 4WD Hi. I also use snow tires all winter which makes a huge difference for me.
Our pot holes could be classified as small mountains.. I may have to rethink my thought process… ROFL.
Just follow Hercule Poirot's car advice after every ride and you'll be fine:
1. Does it have the correct number of wheels?
2. Are those wheels firmly attached to the corners of the machine?
Seriously, a pothole with an attitude can split a rim in halves. Happened to my brother a few years back. Both driver and machine lived to tell the tale.
