User rankings
Jared B
Site admin
Ontario
Just had this brought up to me and thought I would explain the way the forum handles user rankings.
User title ladder
The user title ladder allows you to define a progression for the title that is displayed below a user's name in their posts, on their profile and in various other locations. You may select whether the ladder is based on the number of messages the user has posted, likes they've received, or trophy points they've been awarded. As these values increase, they will receive a different title from the ladder.
Note
The user title ladder is only used if a user does not have a custom user title specified in the profile or in their display styling user group. Those will take priority if specified.
When a user's title comes from the ladder, their title will be the highest value on the ladder that's below their value for the selected field. For example, if you have entered titles for 0, 50, and 100 messages and and the user has posted 80 messages, they would receive the 50 messages title.
Trophies
Trophies add a new element to your forum. They allow you to define certain thresholds and criteria for when a user is awarded a trophy and the associated points. The top trophy point earners are then displayed in the notable members list.
When defining a trophy, you will specify the number of points it is worth and the criteria that is required to receive it. Once a user meets that criteria, it will be automatically awarded. Note that once awarded, a trophy will not be revoked, even if the user no longer meets the criteria.
Our current rankings are New Member, Member, Active Member and Well-Known Member in order from lowest to highest. I will add some higher rankings as well as time goes on. The rankings basically show how active a user is and how valuable others find their posts.
