I found this "removing the box just open to almost full open and then just pull straight out with one hand on each end of the glove box, will take a little force" the best way. it is designed to 'slide out', once you get it out you'll see what I mean, when at this angle, but it does have spring stops that have to 'bend back' thus the 'little force' required.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
