2019 Ram Rebel with 47,000mi, passenger side upper ball joint had a catastrophic failure while driving. Tire ended up into the fender well, taking out upper control arm, snapping lower ball joint, separating CV axle, bending inner tie rod, and bending strut. Over $2,000 (parts) in repairs. What I fixed on passenger side I did on driver’s side.
2 Rough Country Forged Upper Control Arms
2 Rough Country 2” Struts
2 Rough Country Rear Shocks
2 OEM Lower Control Arms
2 OEM Outer Tie Rod Ends
1 OEM Inner Tie Rod
1 OEM Axle
Control arms were touching inside of tires after install. So I got it towed to dealer for alignment and to check all torque specs on new components. Currently waiting on a phone call to determine if the alignment solved the upper control arm/tire issue.
Waiting for parts on the week before Christmas was awful.
