So I found the location of fuse F55, supposedly a 25 amp power source for aftermarket accessories. If I put a fuse in the slot, where is the wire that's fed by it?
That could just be something for the next gen heavy duty models if they plan on using the same fusebox. If not I'd be interested in knowing where it goes as well.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
