Uneven wear
rubikcube
I have a limited ecodiesel with the off road package with the factory falken wildpeak tires. The tires are wearing unevenly, mostly on the outer side. This is on both the front tires.
I’m in the process of getting new tires, but does anyone know what might be wrong? I’m pretty religious about keeping tires aired up. I also tow a 6300lb trailer with a WDH.
DOFF
Just got my truck aligned two days ago with the same issue. Thought the camber might be off. Tech told the “the toe was kicked out”. Said it’s a common cause of quicker wear to the outside of the tires. Hope this helps.
Cbty2050
Get an alignment when you get the tires put on.
