uConnect4 12" -> uConnect5 12" Swap Issues
Doxmia
Alberta, Canada
Heya,
I swapped my radio/screen out for a 2022 uConnect 5 system and for the most part everything worked as expected except for my cameras didn't show up due to me requiring a newer CVPM module (p/n: 56029968AF) which I did swap in but didn't have the security bypass to reprogram my truck. I have a limited trim already so didn't need to program anything else since I was moving 12" to 12".
That being said I got the bypass today, changed my truck year to 2022, cycled it and the cameras showed up. (Front/rear/mirrors). 360 didn't work, it was all black. Every calibration I tried in AlfaODB failed with the same error "Conditions not correct or Request Sequence error". I did everything it said, drive in a straight line between 2 and 8mph, cameras were clean, etc. I tried about 3 dozen times and even tried one camera at a time and just kept getting that same error message. I'm using AlfaODB with the ODBLink MX+.
The other thing I noticed is as soon as I changed my truck to 2022 from 2019 my Adaptive cruise + collision prevention broke and was showing errors in the dash. As soon as I change it back to 2019 it works fine and no errors but then obviously my cameras break. Update: That just fixed itself after a day or so, not sure what is up with that, so now it's just I can not run a calibration no matter what conditions I am in. I've tried driving in a straight line on a lot of different roads and can never start it.
I've tried searching everywhere (these forums and elsewhere) and there's extremely limited information. Hoping anyone (aka @Jimmy07) might be able to help? haha
After trying and failing to calibrate the CVPM with AlfaODB multiple times I just took it to a dealer and they calibrated it in less than 30 mins.
Hello, where did you buy the CVPM at? I am wanting to upgrade my stereo to the newer version also Fromm 2021 to the connect 5. Thank you.
