Typical spacer question
FL19ram
Looking to get a confirmation that a 1.5" spacer will be enough to cover the lugs without grinding? I got new rims that do not have the recessed slots on the back side.
mxz
Courtice, Ontario
I just put on 1.5" spacers on my 2019 Rebel and the lugs do stick out slightly past the spacers. Thankfully the stock Rebel rims have the recessed slots.
Rebel2022
Alberta Canada
Same thing here, lugs stuck out maybe 1mm. Not an issue with Rebel rims but if you don’t have recessed slots you’ll have to cut/grind a bit.
