Turn signal light
Noid
I could have sworn I saw something on here about the directional lights that come on when you turn your steering wheel or use your turn signals. Is there a way to turn this function off?
Yes, my Bighorn L2 uses the fog lights this way. Quite helpful when taking turns on the dark. I don't think this can be disabled and quite frankly I don't know why one would want to disable such a useful feature?
If you turn the fog lights on, the feature is disabled...cause they’re already on
Unless you have your high beams on, the fogs drop out and become turn lights again. Between the auto high beam function that turns on and off at different speeds, and the fog light drop out / turning light function it makes for an interesting light show when driving through neighborhoods where you're fluctuating speed while making turns is right in range for all the auto functions to take place.
Yes, That's actually how I discovered that the fog lights do this, as I always have my fogs enabled. Confused me the first time I saw it happen with my high beams on.
