Tuner?
Vabeso
Clifton
I've been having a horrible time researching what the best fit for a performance tuner for my 2015 5.7 Hemi would be.
I can't seem to find out whether or not it's absolutely necessary to swap out the PCM for an unlocked one. Hopefully, there are tuners out there that don't require a swap.
I've read up about the EDGE Pulsar module but personally, I'm looking for a handheld or dash device that I can use to monitor the system and adjust things that way.
The EDGE uses the up and down buttons on your steering wheel to adjust power levels and also has the added annoyance of having to remove the module every time you go to the dealership. So that type of performance system doesn't fit my needs.
What do you guys/girls think? Any advice or suggestions??
Scram1500
An unlocked PCM is necessary for tuning. Some people drop the coin and just buy an unlocked PCM for a $1000. If you send out your current PCM it's about $500. The annoyance of removing the module goes a bit deeper as the truck keeps a log everytime you unplug the PCM, potentially raising the "you're up the creek" flag at the dealership
Rogues Gambit
Jersey Shore
Good to know
I got AFE shorties and Y-pipe in my garage and am told I need to tune it for gains. I'm just hoping they don't deep dive and I can uninstall the tune for dealer visits
Ellisstrong
Atlanta Ga area
All real tuners will require an unlocked PCM.
Orion10182011
Shelbyville, KY
All actual tuners will require an unlocked ECM. There are some piggyback "tuners" that modify the signal going to the locked ECM. No doubt there is less options with that setup.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Good to know
Not to be pessimistic but they’ll 100% be able to see that you’ve tuned it. Each time you swap PCMs it will flag it.
