Trying to decide what wheel & tire size for lift
And just because I have these photos, this is my truck with 7” or lift, 12 wides, and 35s. Pre and post trimming. removed the mudflap, cut the liner back, hammered the tab that holds the mudflap back. Nothing crazy, but this truck has a big lift and STILL rubs.
In this last photo, your probably looking at folding the corner back to where those bolts are if I had to guess. And will still probably rub in the standard scenarios. And then whatever beaver mod is required for the front.
Thank you for the replies and pictures. The 33s will probably be the route I end up going.
Readylift 2 level with UCAs and 285/75 R18 Nitto Ridge Grapplers ( according to Nitto a touch over 35 inches inflated, they run 11.26 width)...perfection, to me at least...as stated, everyone has different style.
275/70/18 MT Baja boss a/t on Mopar 2" lift. Was going to run 295 but it was cutting it close to the control arms (would have less that 1/4") and fender liner. I want full articulation for trails
Here's my 21 Laramie with a 2" loaded strut level. Nothing out back. Running 305/55/20 Ridge Graps with Fuel Rebel 20X10 -18mm offset. Just enough poke to me without it being obnoxious.
