Trx wheels
Do you by any chance know the size?
Ok this is as good as i can give you on the bolts for the rock ring
Anyone know what the factory tire pressures are on the TRX on the door jam or the dash readings. I just wanted an idea what to run on my Rebel with those wheels and tires. 55psi front is way too high for those tires.
38 PSI cold
They will definitely be available. People are already horse trading them on the Ram TRX forum
Question, can you run the TRX wheels directly on the regular ram new body style 1500 4x4 without spacers ( added, I’m running 6” zone lift ) I’m under impression I’d need spacer and prefer not too use spacer )
Not sure. The wheel does appear to be deeper than the rims that were on my limited, so rubbing may be an issue.
This is them i put on my Rebel after painting the ring blue. Facebook marketplace $2500
Question, did you have too run a .25 spacer in order for these wheels to fit and not rub nor hit the break caliber ?
Those are the ones I want 😬
I now have set of 5, the full set plus spare, brand new take offs , for sale . Texas . 75068. My asking is 1500(obo) ! if interested I do not mind serious inquires BY TEXT ,2147699585.
Do you still have these wheels?
Looking to get those wheels for my rebel. What did you have to run for spacers to get them to clear the UCA's? Do they have the same pocket clearance behind the wheel as the rebel does for wheel spacers?
I went with 1.5” BORA spacers..TRX wheels with stock Rebel tires...
