The TRX bead locks are “capable” of running as beadlocks. But they are delivered as a standard mount. You’d have to buy separate beadlock rings to convert them to true beadlocks.I believe they should fit just fine. I love the look of the TRX wheels and wanted to put them on my regular 1500. But the TRX wheels are "bead lock" wheels, which are great for severe off-roading where you want to air-down to less than 10 PSI. But the bead lock wheels are kinda problematic for any other use. They are more difficult to mount and are more prone to leaking air and are more prone to blowing out completely and loosing all the air in the tire. So I decided to go with some Rebel take-off wheels which I like much better than my factory wheels.
There’s also a non-beadlock TRX wheel.
Here’s a pic of the beadlock-capable TRX wheel. To run true beadlock, you need 24 bolts on the outer ring.
i believe other threads ive seen running these take offs on a non trx u will need a spacer to clear the UCA'sThe ones I’m looking at are the non-beadlock ones
I got some TRX take offs on my Rebel
Ok i did a little change on wheels/tires TRX take offs . No rub on the splash guards but close, i am almost up against the upper control arms i can barely fit a thick paper add between the tire & upper control arms. I’ve used spacers before but it’s so close i might try & grind the tip of the...5thgenrams.com
this thread should answer all your questions
True but any “takeoffs” I’ve seen around me at least come with factory tires which will rub.The wheels fit any truck just fine...it's the large tires that do not. They are just 18" wheels. No problem running those alone (with smaller tires obviously) on a stock truck.
