I don’t know if that was a talk to text issue, but I laughed out loud at thatThe rim should fit no probably.
Post some pictures when you get them on!Nice, will grab them tomorrow quite excited for this steal haha
Wait would it ? i will be using my old 285/65r18 falken on the trx rims once i pick them up.. please say it aint soThis has been covered before. The tire will hit the upper control arm unless you use wheel spacers.
Haha it was. That’s a pretty good mess upI don’t know if that was a talk to text issue, but I laughed out loud at that
I thought that was only if using the 325’s it came with? It sounded like the OP is using a different size.This has been covered before. The tire will hit the upper control arm unless you use wheel spacers.
Jack, I would pick them up. I'm seeing the width and offset on these are the same as a lot of the other trims. Dry fit one, if it hit's your upper control arm them just get spacers or put them up for sale. A lot of people said 35x12.50 on my factory rims would not work with out spacers or a lift and they fit mine just perfectly.Wait would it ? i will be using my old 285/65r18 falken on the trx rims once i pick them up.. please say it aint so
Tire will only hit if using the TRX tires. Tires size was not mentioned in the original post. You should be fine with a skinnier tire.Wait would it ? i will be using my old 285/65r18 falken on the trx rims once i pick them up.. please say it aint so
Did you need wheel spacers? if not can you take a pic of the clearance between your tire and the upper control arm.Excuse the dirty truck, it's been raining past couple days .
Now I just gotta firgure out how to get the black out etorque hood bezel molding for the sport hood and I will be finish with the exterior
Fixed it for you.Excuse the dirty truck, it's been raining past couple days .
Now I just gotta firgure out how to get the black out etorque hood bezel molding for the sport hood, black lug nuts, and I will be finish with the exterior
**** it black lugs it is, imma put my orders in nowFixed it for you.
No just get a good quality hub centric spacer are you should be good.Question... i been looking at getting spacers for the wheels just because the tires are quite close to the UCA within the above pics. I can fit a piece of paper between em but i cant get my whole finger in past it ( prob just the tip of my finger). Anyhow, this wouldnt cause any issues right? as long as theres clearance i should be fine? I havnt noticed any rubbing or shakes or anything while driving.
Let us know how did it go & what spacer did you go with ??Question... i been looking at getting spacers for the wheels just because the tires are quite close to the UCA within the above pics. I can fit a piece of paper between em but i cant get my whole finger in past it ( prob just the tip of my finger). Anyhow, this wouldnt cause any issues right? as long as theres clearance i should be fine? I havnt noticed any rubbing or shakes or anything while driving.
