Those look great!!! I love that color you chose.Finally got mine from powder coat and installed.
These look awesome! Let me know if you are open to trading services! I can do websites.I can build a lot of things. Websites are not my strong suit. A perfect example of my ignorance is, I've never heard of DuckDuckGo.
Yes. The only thing “different” on any 1500 is if you have air suspension. They fit all but with air you need to take off an extra bracket for air equipment.Will these work on a non-rebel? I have a 4x4 BTS with the factory hitch.
John is correct. They fit all 5th Gen Ram 1500s. With the air suspension you have to remove and reinstall an air module or pump on the passenger side.Will these work on a non-rebel? I have a 4x4 BTS with the factory hitch.
Can you elaborate on how much time, effort and possibly parts this might entail?John is correct. They fit all 5th Gen Ram 1500s. With the air suspension you have to remove and reinstall an air module or pump on the passenger side.
The install is pretty quick. No parts are needed. There is a pump or module for the air suspension system that you have to remove the bolts from and move the module to the side to access one of the bolts on the receiver hitch. Most people have their install done in less than an hour. As far as tools, you’ll need a 19mm or 3/4” wrench and socket to install the hooks to the brackets. You’ll need a 21 mm socket and extension to remove and install the receiver bolts and 13mm socket and or wrench to remove and install the air module.Can you elaborate on how much time, effort and possibly parts this might entail?
Thank youNICE JOB!
Thank you! We truly want to offer the best to the best vehicle community. We've been Mopar people since before we could drive and it is an underserved community. We hope to change that but it will take time.Great work!
Some info, 10:45 mark on video.Anyone has these installed on a laramie? or prob a bighorn? i think theyre the same layout. I also have the side step thing that helps you get into the bed. Was wondering if that would cause an issue?
Ohh i see, i guess i can get rid of my steps since i dont particularly uses it hahaSome info, 10:45 mark on video.
