Truckbed lights tie in -12vdc
Jako
Borough of Parks
You can add a Curt 56070 or Hopkins 41157 which will give you all the wires available at the trailer hitch. You will have an auxiliary wire to do as you please. These are designed for a 5th wheel and you will need to trim the wires to your situation.
This is a picture of a Curt 56584 which only has 5 wires, but is installed the same way.
Here is information about reverse lights, plenty of info from members on their reverse lights which is something to be considered.
