The trans in my 2019 Laramie feels like a stick shift car. I can feel every gear.. is this normal, or could it have something to do with driving in 2 wheel drive? Also, is it related to eco mode? I keep seeing eco pop up on the display...
Thanks in advance for the advice
"Feel" is too subjective a term to give you a firm answer, but I don't notice mine shifting, no. It just glides into the next gear smoothly. When it's cold (truck + outside temperature), sometimes the first 1 or 2 shifts might be noticeable until the tranny warms up (which is within a 1 min or two), but it would not have anything to do with driving in 2 wheel drive as that is what you should be doing most of the time.
Eco can occasionally have a "fish bite" effect in my truck when slipping out of MDS, just like a tiny little tug; that appears to be normal as more people say the same thing. You can check if you're noticing MDS, but disabling it temporarily by pressing the +/- keys. Use the gear limiter to limit the gear to 8, and that will keep the truck out of MDS.
