you have opened up a can of worms!Looked in the manual and it doesn't list any transmission service intervals (seems odd) at least nothing I could find.
Is there a factory recommended time/mileage of fluid and filter changes?
My truck has 64k miles on it so I asked for a quote on transmission service and was told $1020 by my dealer. SA said the filter is part of the pan, so a new pan would have to be ordered and the fluid alone is over $200. Is this a load of crap or are those numbers accurate for that service on this vehicle?
Seems accurate when you factor in labor ratesMy truck has 64k miles on it so I asked for a quote on transmission service and was told $1020 by my dealer. SA said the filter is part of the pan, so a new pan would have to be ordered and the fluid alone is over $200. Is this a load of crap or are those numbers accurate for that service on this vehicle?
Most delaer service won't be just a simple pan drop and refill. Will probably be a full flush, which requires more fluid than a filter and fluid change. And takes more time.I think there's a little being added to the top:
$300 for the pan
$240 in fluid
That's $540.
Labor rates @ $150/hr average, seems like they are factoring in quite a bit of labor. If that's the ballpark rate it seems like they're budgeting almost 3.5 hours which is a bit much.
I am trying to find where I saw it but I think I saw someone on here quoted $800 from the dealer which seems a little more inline.
That's just my $0.02 for what its worth. Even my marine diesel mechanic is $175 per hour and I've seen rates there as high as $199 per hour.
Just out of curiosity, do you know how they even do this on those trucks? I imagine they have a fitting for the fill and then let it come out the drain?Most delaer service won't be just a simple pan drop and refill. Will probably be a full flush, which requires more fluid than a filter and fluid change. And takes more time.
Yeah, I'd do it myself. I have a friend with a lift in his shop. However, my SA said she spoke with their "warranty person" and he told her that since it's under warranty (CPO 7/100k), the transmission service would have to be done by them. Which I have my doubts about too, but I'm not willing to test it. I guess I could always call another dealer and ask if that's true.This is where I chicken out and bring it to the dealership, unless the warranty is up. Then I'm doing it myself and using the PPE aluminum pan with replaceable filter
Considering the owners manual says the trans doesn't require service and is "lifetime" fill, there would be no reason for warranty company to even know you changed it, let alone deny a warranty claim because you didYeah, I'd do it myself. I have a friend with a lift in his shop. However, my SA said she spoke with their "warranty person" and he told her that since it's under warranty (CPO 7/100k), the transmission service would have to be done by them. Which I have my doubts about too, but I'm not willing to test it. I guess I could always call another dealer and ask if that's true.
This is just simply not true. You are allowed to get your car\truck services by any shop you like, and that is common knowledge. The lady just wanted to sell you extra crap.However, my SA said she spoke with their "warranty person" and he told her that since it's under warranty (CPO 7/100k), the transmission service would have to be done by them. Which I have my doubts about too, but I'm not willing to test it. I guess I could always call another dealer and ask if that's true.
^^^^Considering the owners manual says the trans doesn't require service and is "lifetime" fill, there would be no reason for warranty company to even know you changed it, let alone deny a warranty claim because you did
It's a very simple and actually takes less time than a pan drop. Fitting in the fill/check hole and a fitting on the cooler line.Just out of curiosity, do you know how they even do this on those trucks? I imagine they have a fitting for the fill and then let it come out the drain?
The actual flush takes less time, but once you re done with flush, you still need to drop the oan to replace the filterIt's a very simple and actually takes less time than a pan drop. Fitting in the fill/check hole and a fitting on the cooler line.
That wasn't the question. Yes if you are replacing the filter then the pan has to come off.The actual flush takes less time, but once you re done with flush, you still need to drop the oan to replace the filter
