Transmission issue
Ram_man
2020 Bighorn, 1500. Only 3500 miles and had a problem with the transmission. When leaving a parking lot onto the street the transmission would not shift out of first gear. I pulled into a parking lot and shut off the engine and put in park. After a minute I started up and left the parking lot and proceed on and the transmission shifted normal. What do you think was the problem. Will watch to see if it repeats.
cdn.tbird
This happened to me once @ a stop light about a month into owning my truck. Freaked me out. It's easy to forget about the buttons on the steering wheel.
U
User_3336
Guest
been there, done that. it does freak you out, because you can't react quickly to correct it.
Jako
Borough of Parks
I had an issue of not coming out of first. It had to sit for an hour or so and it was OK. Stopping, shutting it off and restarting did not work. It was the battery, replaced under warranty. No issues since.
