Montana_
- Sep 29, 2024
Next time I’m going to bend up a 180° “hanger” tube to put in the filler hose so that it will hang in the trans fill hole while pumping.
Now that the drain plug is accessible I plan to drain and fill at 40k and filter/fluid at 80k. At 78,xxx my fluid looked excellent and the magnets had literally 0 trace of any metal.
Was happy to see that. Picked up enough filters to get me to 300k on services.
I ended up getting about 7 quarts in it before I ran it through the gear procedure then an additional .5. It wasn’t leaking anything at around 90° and from that to 100° it was very over filled. I’d say high 6 to 7 is probably the perfect fill. Might require a small top off at temp. I had a very small but steady stream out of the plug when I put it back in (rear end on jack stands and pan rails level to earth).
I think I saw in the video that's what they did to keep the hose in place too? I've definitely seen it before and since you mentioned it, I recall the struggle of trying to pump and hold that tube in place. Good suggestion to remember.
