It can be messy since the exhaust runs right underneath the drain bolt/pan. You have to replace the pan and make sure you use the proper spec fluid (either MOPAR or ZF Lifeguard 8).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
