Transmission Bell-housing Leak?
Definitely see the dealer. The drip I had was not like your pics. I did hit it with some brake cleaner at 2K and it never came b:sleep:
Definitely see the dealer. The drip I had was not like your pics. I did hit it with some brake cleaner at 2K and it never came back.
I just bought a 2020 bighorn a few weeks ago and noticed while doing an oil change after 1K miles of break in that there was a small drip in this spot. I wiped it off thinking maybe I splashed some oil when I drained it. That was about a week ago, then today I remembered and took a look and there it was again, a small amount. It’s not dripping (near as I can tell) on to the ground and seems to take a while to come back. Do you think it’s probably the grease people seem to be running into? If it comes back I’ll post a picture, I didn’t think to this time before I wiped it again.
Noticed this leak while changing my oil the other day. 2020 Ram Rebel with 20k miles. I doubt this is assembly grease. I wiped it clean the other day, and 24 hours later, here are the pics. Does this look like oil or ATF? Making an appt with the dealer….
As I recall the ZF fluid is a greenish color. I'd have to say it looks like motor oil.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 053727 miles.
