Chippewa
- Jan 13, 2020
2019 Tradesman. Adding cig lighter an passenger usb ports. Pop lowest skinny bezel real carefull. Then open glovbox an start at base off lower tray trim bezel being even more carefull. Watching the push button area pinching. Just pull straight out an off. Next grab a long P2 screwdriver carefull to remove an not drop down into dash junk. Then pop straight out pulling on main structure not glued on fascias.
My plan is unibit two holes thru passenger side blank area. Adding two sockets an power off an aux power wire I ran thru firewall to a switch panel I made underdriver side dash area.
Maybe these pics help somebody. Always eire to yank dash parts apart.
