Traction and ECS control
Vewdew22
How can you disable ecs on the 5th gen?
I’m able to turn off traction but can’t find a sequence to off ecs as well. Unless it’s in 4 low it doesn’t turn off. How am I supposed to roast these tires?!!!!
I’m able to turn off traction but can’t find a sequence to off ecs as well. Unless it’s in 4 low it doesn’t turn off. How am I supposed to roast these tires?!!!! Visit Autoguysland site to view more issue of traction control and abs light that you may concern.
Automatic brakes will not be available if ESC is not available. Therefore, i think you will disable Automatic brake by Customer Programmable Features section of the Uconnect System, it will be disable ECS too.
Page 189 of the manual
Full Off — If Equipped
This mode is intended for off-highway or off-road use only
and should not be used on any public roadways. In this
mode, TCS and ESC features are turned OFF. To enter the
“Full Off” mode, push and hold the “ESC Off” switch for five
seconds while the vehicle is stopped with the engine
running. After five seconds, a chime will sound, the “ESC Off
Indicator Light” will illuminate, and the “ESC OFF” message
will display in the instrument cluster. To turn ESC ON again,
momentarily push the “ESC Off” switch.
I believe that only in 4x4 can you disable all traction and stability control. Tazer is the best/easy way to disable features of the 5th Gen.
OP has a 4X4, otherwise he wouldn't know it goes off in Low Range. So in his case, the easiest way is to hold down a button for five seconds. It doesn't cost a thing and if it doesn't work, he's only out five seconds of his life.
Correct, but he wants to do a burnout, not possible in 4x4. You can actually do a brakestand with just traction control off, as long as you keep the truck straight... otherwise stability control kicks in. That's without the Tazer... with the Tazer you can enter a drift competition if you so desired!
You can turn the Traction Control off in 2wd, and do all the burnouts you want. However, you cannot turn off the Vehicle Stability Control unless you are in one of the 4wd modes, (4A, 4H, or 4L). If you want to blow donuts in a 2019 Ram, pull the ABS fuse and have fun.
I took my truck out at lunch and you are correct, sir. Pretty lame that we can't turn it off in 2WD. What part of "Off" do they not understand?
I think they were worried about liability rather than burnouts. A switch could probably be rigged inline with the fuse.
hold down traction control and tow/haul at the same time for roughly 5 seconds until the pictures are gone from the dash screen.
^^noted. im about to test this when I get off work in about 1.5hrs.
Damn. I'm really going to spend 329.99 just to do donuts...
I mean give it a shot and try a burnout/donuts. I didn’t go to that extent. There was just nothing visually stating a form of advance traction control was turned off
