Stevensx21
- Jan 29, 2019
Here is some photos of my 2019 ram 1500 towing a jayco 32KBS. Photos are with and without the weight distribution hitch installed. Must say it makes a huge difference. I made a trip from Pensacola, FL to Corpus Christi, Tx with this setup. It was my first time with something this large so I must say I was nervous. I didn’t really have many issues until I got closer to corpus as the winds picked up to 20 kts. I would recommend getting a sway control for both sides as I was constantly steering slightly to the right since my sway control was mounted on the right side. The motor was plenty powerful the only issue was the weight of the truck versus the weight of the trailer. The truck was pushed at times by the trailer so you def had to be paying attention but for the most part I was doing about 60-65 and then 55 when the winds picked up. Temps stayed fairly normal with transmission rising to 183 and psi in tires about 4 above average. But all was within range so i was very impressed. If you have any specific questions pm me.
