Tow Hook Kit for 2025
Can you install the JDM tow hooks above on a 25 Laramie without having to remove the long 18 mm bolt. I believe they hook in and use the rubber bushing and hardware provided with no bezel covers needed. TKS Roger
I removed the long bolts to install.
Just put the rough country tow hooks my 25 1500. The driver side weird. Any Ideas??IMG_5485.jpeg
hmm, I would say the driver side one is bent unless your frame mount is bent but I dout that if the bumper is straight.
I have a 2025 Laramie Sport. I just installed these today. They fit perfectly. No need to change out the bezel at all.
JDMSPEED New Heavy Daty Front Car Tow Hooks Left & Right with Hardware Black Replacement for Dodge Ram 1500 DT with 3.6L 5.7L Engine 2019 2020 2021 2022 Replaces 82215268AB 82215268AB 68272945AB https://a.co/d/8cRsB30
With JDM speed, do you have to pound out the long bolt. I have a 25 Ram Laramie.
