Biga
I just picked up a 2025 Laramie sport yesterday. Does anyone know if the 2019-2024 Tow Hooks will fit a 2025? I know the bezel would be different but wasn't sure if the hooks themselves would be since the bumper is different.
Thanks for the feedback, I have a message into my parts department about it. One thing it seems is that the panels on the bumper look to be easier to get off then the ones on my 2019, just some pushpins on the backside of the bumper and it looks like thier are not seperate bezels needed from the 2025 trucks I've scene that have them.I understand the frame is the same but the front bumpers and valence are different. Also, the new engines may play a part in the mounting of the tow hooks due the the slight variation of the engine mounts. I would ask the dealer parts folks. They may have the answer(s). Some of the 2025s do come with the tow hooks from the factory. Try taking a VIN then go to the parts dept. and have them look up the tow hook part number for that truck and then see if that part number would fit your VIN. A little time and leg work may provide the answer for your truck. Also, RAM may not have designed certain trims to not have the tow hooks. I know that the Limited does not have tow hooks so, that may be the problem with your truck as RAM has not designed it for tow hooks.
As I am not in the market for a 2025 model truck, too expensive for many reasons, I have not given it much thought.
BlueHemi1500
Did you ever hear back on this?Thanks for the feedback, I have a message into my parts department about it. One thing it seems is that the panels on the bumper look to be easier to get off then the ones on my 2019, just some pushpins on the backside of the bumper and it looks like thier are not seperate bezels needed from the 2025 trucks I've scene that have them.
Yup. That’s the route I went. The finish on them is great and super easy to install. They fit perfect and on the 2025 you just pop out the “tow hook delete” insert. No new bezel required.I've also been looking at the Rough Country. They seem to be a quality product and the install is easier since you don't have to pound out the long bolt, just loosen and slide over.
Tow Hook Brackets | Ram 1500 4WD (2019-2021)
Tow Hook Brackets | Ram 1500 4WD (2019-2021)www.roughcountry.com
Nice. For 2025 they got smart in not needing a separate tow hook bezel.Yup. That’s the route I went. The finish on them is great and super easy to install. They fit perfect and on the 2025 you just pop out the “tow hook delete” insert. No new bezel required.
Not on my LoneStar. Maybe the higher trims.I know this is of topic but have any of you with a 2025 Ram have been able to lower the windows with the key remote?
Try putting some 2x6 boards on the ground right in front of the ramps- it should lift the truck up enough to clear the ramps.Guys,
I ordered the JDMSPEED version from Amazon.
Tried do drive up my ramp to get the truck higher off the ground to start the installation.
Problems:
My ramps are 12 inch high and the chin is too low and hits the ramp. So, I did not do the install.
Is the floor jack mounts for the front on the rear of the wishbone? Did google search, not much info on how to lift this truck using the floor jack.
Do you have to remove the fender liners to get access to the mounting points?
Somehow - I had a much easier time to get the hooks installed on my 2019. Had to remove the fender liners though.
