Top Hat Lift -Is it a 1 to 1 lift ratio?
Lawfin
I have a 5th Gen Big Horn Crew Cab with the Mopar 2” lift. I’m considering adding a top hat spacer to bring up the front. I’m thinking about the MaxTrac 1.5” Front Strut Spacer Part. No. 832515. My hope is that if I go with the 1.5” spacer, I won’t need new UCAs. And, I’m only interested in 1.5”, as any more will result in an inability to park my truck in my garage at work. My question is: Will a top hat spacer of 1.5” result in 1.5” of lift, or will it result in more or less? Thanks in advance.
Nails
San Antonio
If you got the full mopar lift kit. It comes with diff UCAs. So you should be fine with more added. As for spacers they are in most cases pretty spot on with true lift.
rsonedecker
Top-hat spacers are not 1:1, but most (not all) manufacturers list the NET lift, not the height of the spacer. You might want to reach out to the manufacturer and ask if they can verify that their spacer does just that, and on a 2019. What I've seen is that spacers that are about 1 1/8" tall result in an actual lift of about 1.5"-1.6".
rsonedecker
The images of the spacer in question make the spacer look to be short enough, but their documentation indicates "it's a 1.5" spacer that produces 1.5" of lift" - that's what can be confusing. I bet it's not actually 1.5" tall. You could always pick it up and just measure it before you install just to be sure.
Lawfin
Thanks for the input, everyone. This may seem like a stupid follow up question, but . . . Is it the thickness of the spacer or the lift it creates that has the potential to cause angles that may compromise the UCA ball joints?
rsonedecker
In theory both, since the thickness of the spacer creates the net lift that then in turn creates the angle problems. But that's just a smart a$$ remark from me because I know what you're getting at - it's the lift and the angles the lift creates that causes concern. The more lift, the more concern.
Lawfin
Ha! My question begged for a smart a$$ response! Thus the “stupid question” disclaimer. I appreciate your response. I have seen discussion on other forums (relating to other vehicles) about the lift being less than the thickness of the spacer. It looks as if that is not the case with the ram 1500s. Thanks again.
Ram1992
Houston TX
Did you end up installing that top hat spacer on the Mopar kit?
