I just looked at em and they seem pretty steep. Unless it comes with the rails? I'm sure there's other similar options for probably half the price of 2k. Are you looking for something to fit with the racks that are mounted low or high? I guess if you like the low racks then retractable is probably the only thing that's work. But if it doesn't matter if they're low then anything that's doesn't cover the stake pockets should work.I'm looking for a tonneau cover and have my eyes set on the Retrax XR Pro. I like that it's aluminum and has the slots for racks. Has anyone used this before or have other suggestions? Thanks!
They’re not inexpensive, that’s true. But if you’re seeing half the price, I wonder if your comparing plastic/polycarbonate to aluminum. Retractable covers like Retrax are available in both version. With Retrax, aluminum is about an additional $500. The XR rails add about $100. So the least expensive version is around $1300, while the most expensive is around$1900 (actually, you can add another $700 for electric).I just looked at em and they seem pretty steep. Unless it comes with the rails? I'm sure there's other similar options for probably half the price of 2k. Are you looking for something to fit with the racks that are mounted low or high? I guess if you like the low racks then retractable is probably the only thing that's work. But if it doesn't matter if they're low then anything that's doesn't cover the stake pockets should work.
I want the low mounted racks and aluminum for the cover. Retrax was the only brand I've found so far with both the rails and aluminum.I just looked at em and they seem pretty steep. Unless it comes with the rails? I'm sure there's other similar options for probably half the price of 2k. Are you looking for something to fit with the racks that are mounted low or high? I guess if you like the low racks then retractable is probably the only thing that's work. But if it doesn't matter if they're low then anything that's doesn't cover the stake pockets should work.
