So I'm contemplating ditching the factory Duratracs for larger (285/75-18) Falken AT3W's. 33.4" vs 34.8" tire.... the problem I have is that the Duratrac weighs 54 lbs and the AT3W weighs 66 lbs. 12 lbs MORE rotational weight at each corner. Can anyone who has moved up to larger Load Range E tires with 10 - 12 lbs more weight tell me if you regretted it? Were there any down-sides to your move? That's a lot of heavy rubber that may be super overkill for this 1/2 ton truck.
Thank you for any experiences you can share.
