Tire specs help
Lungs414
I am trying to find specs for Yokohama helps set G015 and Toyo AT3 Specifically the height in inches between th the rim and outer tred. Tire size . Com has some but not that measurement. I have. 2” mopar lift and I want to see how much the tire will fill up the wells.
thanks in advance
Lungs414
OK that's easy. I asked tirerack chat and they didn't know. Your suggestion makes sense
Thanks
Lungs414
You mean like take the height of the tire, subtract the rim, and then divide by 2?
So I just checked my 22's. Goodyear 285/45/22. Tiresize .com has the following specs.
For height diameter is listed as 32.1 , So I did the math, 32.1-20 =12.1 / 2 = 6.05.
then I measured the tire and the sidewall is 4" s. So something is not right. Only 4000 miles on them.
Did I do it right
LaxDfns15
Memphis, TN
285 is tire width in mm = 11.22 in
45 is the % of width that is sidewall height (including tread) so you do 11.22 * 45% = 5.05". You subtracted 20 from tire height instead of 22, otherwise you would have gotten the same answer.
Lungs414
Thank you. My new wheels are 20's, can't believe I did that.
