Thanks guess I’m going with 275/65/20 and if I need spacers I’ll get some... just need some bigger and better tires for light off-road and traction..Yes and no. If you’re keeping the factory wheels the offset makes the tire uncomfortably close to the upper control arm with the wider sizes. Also some 35’s are 34.5 and some are 34.8. It can fluctuate.
275/65 (34 x11) will fit no problem. 285/65 (34.5 x 11.5) will fit but will be a bit stuffed. 295/60 (34 x11.8) gets a bit close to the UCA.
let me toss this at you... 285/60/20 is 33.5x11.5 but the Nitto Ridge Grappler is 33.7 in the same size. It runs a little taller but you keep the 11.5 width.
The Rebel stock tires are 33.2 x 11 for reference.
Hope this helps.
Did you ever get those tires put in? Do 275/65r20 rub at all?Thanks guess I’m going with 275/65/20 and if I need spacers I’ll get some... just need some bigger and better tires for light off-road and traction..
Haven’t had time so busy but plan on getting soon!! Debating really hard between those and 285/65/20Did you ever get those tires put in? Do 275/65r20 rub at all?
I thought about 285s also, but the wife put her foot down on that one, so 275 it is for me.Haven’t had time so busy but plan on getting soon!! Debating really hard between those and 285/65/20
And any rubbing on those? Pics?I thought about 285s also, but the wife put her foot down on that one, so 275 it is for me.
I haven't gotten them yet, I was just saying that will be the size I get.And any rubbing on those? Pics?
Couple of pics if it helpsAnd any rubbing on those? Pics?
Yes very clean look !!!! Thank you and well doneCouple of pics if it helps
