Tire size, fitment, look and backspacing help! Please!!
BJackson81
So I want to do this right the first time! I have a 2 inch leveling kit from motofab on the way. It's the spacer that goes on top of the strut, not the ones that add preload and compress the coil. I did that to a truck in the past and it made the front suspension way to stiff.
So I want to go with a Nitto Recon Grappler in a 315/60r20. The regular duty tires in the standard load rating.
I was told these will fit with my stock rims? If they do fit I'm wondering if that will give me the look I want? Looking for a little poke as I want to add rough country pocket fender flares paint matched to the truck.
If the stock rims aren't going to give me the stance I want. What offset will?
Any pictures to help me decide would be awesome. Please help! Thanks!
2021 Ram Big Horn Night Edition, 12" screen, electric running boards
This is a 305/55/20 with a +1 wheel and a 2” level. About an inch of poke with this set up.
Let me know if you go with the 315/60/20 recon's. I'm debating putting them on next spring and running them during the spring / summer months.
Looks good bro! What does a +1 wheel mean? +1mm offset?
Thanks!
Thanks man, that was my 2020 Laramie. +1 offset on those wheels, don’t remember the exact backspacing but really liked the set up.
2020 Bighorn with 2.5" Motofab level and 305/55/20 Venoms. These are stock wheels, slight rub when fully turned in reverse but no trimming needed.
How close are they to the upper control arm? Thanks
Here is my truck (2022) BigHorn with 295/65-r20 (35.1 x11.2") on stock rims. I did a 2" spacer on top of the coil and UCA's for 2-4" lift.
I also did 1 1/2" wheel spacers..... don't know what the offset is with the wheel spacers.
They only rubbed on the little tab to the rear of the fender. Did the "molding heat trick" and formed the fender liner. I did cut off the tab. No more rubbing, even at full lock and going over bumps and dips. Plenty of clearance to the UCA's.
The tires are just inside the rear flares, flush at the top of the fronts.
I like the look now.... couldn't stand the look with the stock tires.
