Tire size, fitment, look and backspacing help! Please!!
BJackson81
So I want to do this right the first time! I have a 2 inch leveling kit from motofab on the way. It's the spacer that goes on top of the strut, not the ones that add preload and compress the coil. I did that to a truck in the past and it made the front suspension way to stiff.
So I want to go with a Nitto Recon Grappler in a 315/60r20. The regular duty tires in the standard load rating.
I was told these will fit with my stock rims? If they do fit I'm wondering if that will give me the look I want? Looking for a little poke as I want to add rough country pocket fender flares paint matched to the truck.
If the stock rims aren't going to give me the stance I want. What offset will?
Any pictures to help me decide would be awesome. Please help! Thanks!
2021 Ram Big Horn Night Edition, 12" screen, electric running boards
Josh24
This is a 305/55/20 with a +1 wheel and a 2” level. About an inch of poke with this set up.
Let me know if you go with the 315/60/20 recon's. I'm debating putting them on next spring and running them during the spring / summer months.
BJackson81
Looks good bro! What does a +1 wheel mean? +1mm offset?
Thanks!
Josh24
Thanks man, that was my 2020 Laramie. +1 offset on those wheels, don’t remember the exact backspacing but really liked the set up.
SiearsK
Zachary, LA
2020 Bighorn with 2.5" Motofab level and 305/55/20 Venoms. These are stock wheels, slight rub when fully turned in reverse but no trimming needed.
