I have a 2021 1500 Laramie with adaptive cruise, air suspension, etc. I went to change tire size and followed the AlfaOBD process of setting the circumference in 2 locations of the BCM and then going through the ABS initialization process. I try to reset the codes, but when I turn the key off and back on to do the rolls test reset as directed, the codes are still there. I have set tire size back to stock and kept trying the same ABS process with no luck. Someone please help :-(
The following codes are still there:
C2212
U05BF
C10D0
Lights showing on dash include what looks like Park brake "((P))" but with an "!" next to it. Yes the park brake works just fine
No FCW available warning
No Cruise control available warning
Some kinda light with a truck and "!" next to it.
C2212
U05BF
C10D0
