Tire Rub with Stock Size
MNMEAD
Minneapolis
Apologies if this has been asked already - did a search but came up short.
I've been dealing with tire rub for about 8 months now, finally am sick of it enough to ask someone. I replaced the stock tires on my '22 Bighorn with stock size K02's. At full lock to the right I get rub when in reverse. My BIL has a 2021 with the same issue, stock tire size as well, but different tires than I. I've looked at both trucks and cannot figure out exactly where it is rubbing. There appears to be plenty of room at full lock, so it must also depend on suspension load. Scares the crap out of my every time when I go to back in or out of a parking spot and hear that crunch, and I've had people walk back to make sure I didn't just hit their cars. I'm positive it is the lugs grabbing something on the wheel well liner, just cannot figure out where. Sounds stupid to type out, but I figured I'd take my hits and get this figured out. Anyone dealt with this issue and figured out exactly what area to cut and/or heat and bend?
Sure you're not hearing the LCA hit the spindle? It's metal on metal contact.
I am not... Would swapping to a meatier tire of stock size cause enough change in the angle to get that to touch? I don't have enough experience with this stuff. I will look again.
It's possible. Your thoughts on it rubbing while backing up are also possible. Someone standing outside the truck while it happens would be the best source.
Are you using the factory rims and the same factory-size tires?
If you went wider or changed rims or tire size any or both could be your reason for the tire rub?
Is there any obvious points that the tires are rubbing that can be noted upon an exam of the wheel well?
BlueHemi1500
I finally figured it out. Factory 20" rims, factory tire size. Tires don't touch at full lock until there is suspension input, which is why I couldn't find anything touching when I crawled underneath. The upper liner where it hags down in line with the front of the LCA just dangles there and catches lugs. I just bent it back and stuck it behind the two bolts on the frame, but will take a dremel to it and carve it out later.
Glad you figured it out. Does it look like the plastic liner has come partially undone vs. the factory installation aka missing screws/bolts?
BlueHemi1500
