Tire rotation question
bocco
Does tire rotation require reprograming the tire pressure system so it knows which wheel is on which corner? I've had cars in the past that required it.
834k3r
Neither the tire rotation page nor the TPMS page in the Owner's Manual mention reprogramming/recalibrating the sensors after rotation. Maybe the service manual does?
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
No you don’t need to do anything other than adjusting psi. If you rotate front to back obviously your front tires now have the psi of the back ones and vice versa.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Always been that way for me too . Most Rams have the same psi front and back but the rebels are different .
Yeah I always run less in the rear for daily driving. For my tires I run 42 front and 35 rear when warmed up
TNRamGuy
Knoxville, TN
Why different pressures? I air down a little bit in the Nor'easter months or if I am going hunting and going to be of road for a while, but all 4 the same
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Because the front of the truck is quite a bit heavier than the rear
Rammit
SE Michigan
The tires will all show the correct psi. It may take a few miles like one poster said, but they will synch.
