Tire/Rim/Lift for 2020 Ram Rebel
jw65
Quick question, have a 2020 Ram Rebe 1500 l Night Edition. Want to install the 3.5 inch readylift , 20 inch XD Gauntlet rims, 0 Offset with Toyo RT 37x12.50x 20 tires.
Am i going to have any rub or steering issues with this config? Thanks
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
You’ll have a crazy amount of rubbing, but if you do it please post pics and let me know how it works! I want to do 37s on my 4” lift but the 35s already required metal cutting
antwon412
It all depends on offset it seems like. I have a Rebel. 1 inch factory lift
with just a simple level kit in the front I fit 35s with absolutely no rubbing whatsoever. Didn’t have to touch anything in the wheel wells.
And yet the poster above me has a 4 inch lift and said he had a lot of rubbing and had to cut metal.
my wheels are 18 x 9 with a plus one offset.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Yeah I have 20x10 -24 offset with 35x13 tires. My lift is probably about 1.5” higher than yours too. I really want to run 18x9 -12 with 37x13.50s & add the ORP springs up front, so I’d be at 5.5” lift. I don’t mind trimming more since I already had to cut metal, but not if it means cutting into the bumper or outside of the fender. And I like to actually use my truck off-road too so I don’t want the 37s to fit on the street and then get stuffed when off road lol
I am curious to know as well what it takes to get 37's to fit on a 2020 Ram Rebel. Adding Falcon performance shocks.
jw65
Thanks, I think I will stick with 2 inch leveling kit and 35x12.50's
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
You’ll probably find it a little more difficult fitting 35x12.50s than his 285/75r18s since the 12.50s are a little more than a full inch wider. That’s basically like running a -12 offset wheel compared to his +1
