What does the tire say for Max Pressure? Go a few PSI below if a P tire, if an E load LT tire then may need to go even lower based on how light the truck is for the tire. if 80PSI, may want to start at 55psi and adjust from there.
I have never bought into that a car manufacture can decide on what a tire pressure should be as they did not manufacture the tire. Chevy loves to say lower pressure so that the tire takes more road bumps and creates a smoother tire. Yet I see many Chevy's with tires worn incorrectly, with the edges wearing faster (shows low inflated tires).
I have gone through dozens of sets of tires on different vehicles (Sport car, SUV to diesel pick up) and found that if you start off just below the max pressure it is a good starting point and then you can adjust the PSI based on ride, traction and wear. IE 44 PSI tire, I run between 40 & 42. On an E load tires where 80 psi is max, I would run 75 front and 70rear on my 3/4 ton diesel. In over 30yrs of doing this, I only had one set of tires start to wear incorrectly and that was a set of Michelins at about 65% life used, found out others were having the same issue so it was a tire fault.
When i had my 3/4 Ton Dodge Diesel, i would adjust tire pressure for when I was towing, or a bed load or running around empty (mainly the rears)
