Is that 51 lbs the recommended pressure, or the maximum pressure? For tires that size, most of the time that is around max pressure, and you almost never want to be running at that. I run mine at around 36-38 PSI.I have Wrangler Fortitude HT 275/65R/18. The Goodyear chart says 51lbs. I've been keeping it at 45lbs before reading the chart. What have you found best in your experience. Thanks
^^This if you're running original tires under "normal" conditions. Once you replace them, whatever is on that sticker goes out the window depending on the type and size tire you install.Whatever is on the door is the best for the vehicle.
