Tire clearance
Fer’s5thgen
2019 limited off road package recently deleted the air ride and replaced with Eibach Pro stage 2R it’s sits level and slightly higher than a stock 5th gen currently have 20x10 -18 Fuel wheels with 285/55R20 thoughts on what it would take to clear 35/12.50? At minimum I will go to a 33/12.50
I have a Limited with a 2.5" lift/level and clear 285/55/22 (34.6" X 12" actual on wheel) and -18 offset. I think you will clear the 35 x12.5 as others are clearing 33/12.5 stock. However, with your lift, go bigger OD and stick to the metric size for assurance (285/65/20) and save a little weight. Even if you have minor rub with the 35", many threads show you how simple it is to reshape the plastic molding with a heat gun and/or zip ties. I fit my 34.6" tires without rub before I leveled with some heat gun love...
