35"s aren't fitting anything stock without rubbing!I've seen 285/65r20 thrown around as about the max tire size you can get on a stock ORG suspension, but I don't know if that was for Air or non-air.
What is that like 265/50?I'd say 33x11.50's would be a good fit.
275/60R20 would be closer but some companies actually make a 33x11.50R20 though.What is that like 265/50?
What did you end up with? I just ordered a 2023 limited with ORG/air and I’m going to switch out for stock 20” rims first thing. Trying to figure out the biggest tire I can fit without any modifications.I searched the forums but could'nt find anyone asking about this specifically. What is the biggest tire I can fit without rubbing on my 2020 Quad Cab with factory 1" lift, 3.92 Rear Axle and 20" rims.
Ok ,that looks good, how much is your truck lifted?I have the Yokohama’s in that size
He's including the half inch estimated for the lip of the rim. So 9" wide, 0 offset = 4.5" + 0.5" = 5" backspacing.I'm old school and use the term backspacing almost exclusively myself. So help me out a little to understand this. You have a 9" rim and 5" backspacing and that equals 0 offset? Are you saying offset FROM OEM? I thought offset was from centerline of the wheel? Sorry, I don't remember which way was positive or negative.
