Ramzilla01
How do you tune the throttle response, when I step on it it seems to hesitate a bit is that due to gears or….
I read this here, but I am not going to spend half an hour searching for it.
Turn to run without starting. Slowly depress pedal to the floor then slowly release it. Do it a few times. Then shut off. Then start like normal. It seemed to work for me. And it costs nothing to try.
Good point. @Ramzilla01, make sure you're not on the oil life screen when you do this.That's how I used to reset my oil life sensor![]()
Thanks, your thumbnail has been bothering me, I’m sure that’s the bad guy from the mighty hero’s but I can’t think of his name….and I refuse to google it lol Simon Barr sinister I’m guessing just thought of itGood point. @Ramzilla01, make sure you're not on the oil life screen when you do this.
Or was that underdog damn itThanks, your thumbnail has been bothering me, I’m sure that’s the bad guy from the mighty hero’s but I can’t think of his name….and I refuse to google it lol Simon Barr sinister I’m guessing just thought of it
Simon Bar Sinister from Underdog. He had a henchman named Cad.Or was that underdog damn it
Do you have one or know how it works. I can read the crap on the website but I’d like an opinion from a user![]()
Pedal Commander® - The Best Throttle Response Controller
Pedal Commander® Throttle Response Controller is the ultimate upgrade, engineered to eliminate throttle lag and deliver instant throttle response. It is also the best vehicle security system with an add-on anti-theft feature. Discover how Pedal Commander® unlocks your vehicle's potential and...pedalcommander.com
common issue….. lots of threads on it, most common fix was a pedal commander.
I have a Banks if you would like to try one out before you make a decision. It’s small so postage won’t be much, HI to PA. Shoot a dm if you would like to give it a try. LatersI've been thinking about getting this, but I'm mostly used to hitting the gas about a second and a half beforehand. Like, logic suggests that when you're in the right lane and want to move into the left to pass, you signal, and then start hitting the gas as you move over. But it comes naturally to me at this point to start hitting the gas when I signal, and then start moving over.
Same thing with merging and other similar instances. I almost always end up hitting the gas a second or two before I know I will actually need the speed increase. Am I my own pedal commander, or is having such a thing a different experience entirely?
Different experience.I've been thinking about getting this, but I'm mostly used to hitting the gas about a second and a half beforehand. Like, logic suggests that when you're in the right lane and want to move into the left to pass, you signal, and then start hitting the gas as you move over. But it comes naturally to me at this point to start hitting the gas when I signal, and then start moving over.
Like I said about the Banks Pedal Monster, it made a huge difference. You no longer have the mush pedal and you get instant feedback and power. The thing I really like is the ability to fine tune the sensitivity with the multiple levels within the 3 modes. It wakes these trucks up like crazy.I've been thinking about getting this, but I'm mostly used to hitting the gas about a second and a half beforehand. Like, logic suggests that when you're in the right lane and want to move into the left to pass, you signal, and then start hitting the gas as you move over. But it comes naturally to me at this point to start hitting the gas when I signal, and then start moving over.
I paid $275 straight from Banks. I think the $275 isn’t that high of a cost for what it does to the Ram. We’ll worth it in my opinion.Different experience.
If it's actually worth the high cost... You would have judge for yourself.
I think, if you purchase it directly from them. You can it for 30 days and return if you don't like it.
It is mostly a toy thought in my view.
