throttle body adaptor
neckbone
has anyone used an adaptor for installing a larger throttle body from say a hellcat
theblet
Idk, but it’s not necessary if you engine is stock. What mods do you have?
neckbone
a lot of mods to the truck but i have a garage full of stuff for the engine to install once my long tube headers arrive. Cam kit with mds delete kit and 8 degree faze limiters ,new timing set, hellcat lifters hellcat oil pump, hellcat head and rocker bolts, ported 392 intake and using the 392 fuel injectors, ported hellcat throttle body, corsa pure core cold air intake, kooks SS long tube headers with high flow catted mid pipe, corsa SS cat back exhaust, unlocked pcm with diablo tuner with engine and trans tune from hemi fever! sounds like a lot of **** now that ive wrote it all out. holly cow!!!!!!!
theblet
Wow that is alot! I think you need a super charger too tho. ;)
neckbone
it will come in the near future. everything but the intake needs to be done before the super charger can be put on. its a dam good thing i know how to install all this **** myself cause the labor would just be crazy
If you are using a 392 intake, what do you need an TB adapter for?
neckbone
originally, i was going to use my stock intake for now and was looking for an adapter but you still cant bolt a hellcat TB to 392 intake. also, i found the adapter i need anyway
