Those with upgraded (larger wheels / tires) - What do you do for a spare?
Psyonic64
Fort Worth, Texas
N00b question. I bought my truck off the lot. It has dealer installed lift and these big-assed Terra Grappler tires.
(305 /55 R20 121S E2 BSW)
The spare is (I assume) the factory provided "temp" 245/70 R18.
This size disparity (should I blow a tire) basically renders the spare useless, doesn't it?
For those of you who've upsized your wheels/tires - do you buy a 5th for a spare? Would it even fit underneath?
R
Rob5589
Guest
You can run it, with some caveat's; don't run it in 4 wheel drive, not a good idea to run it on a limited slip. Other than that, you'll be fine for short distances until you get the main tire repaired.
JHRebel
This...not for long term use but it’ll get you home or to a safe place until you repair or replace the tire.
kittyjo
Will a 35/12.5/20 fit underneath as a spare?
U
User_21361
Guest
Apparently the stock rebel (275/70/18) size duratracs fit under there. I plan to get a matching spare.
JHRebel
Yes it will, but the lack of accommodatIng larger sizes is an oversight on RAMs part imho, jeep has done a decent job considering that and I wish ram would follow.
wiendog
I can fit a 305/55/20 under the truck.I am looking for a 6 lug 20 inch spare wheel though.
