Darksteel165
The seat belt chime is for any seats (you only do the "trick" in the driver seat)How would these be accomplished?
I've see the seat belt chime hack for the driver's side. guess I wasn't aware that worked for passenger also.
My father doesn't like to put on his seat belt when i'm just taking him around the corner or whatever but the chime goes like every 15-30 seconds.
I can look it up but it involved putting the driver side seat belt in, putting the truck into run and unplugging and plugging it in 3 times then shutting the truck off (should honk)
for the DRL change, make this change via the ODB2 port using ALFAOBD
CBC Features: DRL Lamp Location - Turn Signal DRL
If you want the bottom lights (signature light) to stay off when the amber DRLs (up top) are on you make this change also
CBC Extern Light Calibr: Signature Light Present - No
It's not possible to the bottom to be Amber as there are no Amber LEDs in the bottom, only on the top.
The 1 thing the Tazer can do differently is force your blinkers (amber DRL) to stay on when your headlights are on. That can't be done with the regular system as they are reserved for blinkers. when the full headlights are turned on (not to be confused with parking lights or DRL, those will stay Amber).
Hope this helps.
