Tazer question
kmorrow63
IN
Can a Tazer control the air suspension on a 2019 1500 limited to level it out instead of getting a leveling kit? Leveling kits just trick the position sensor anyways.
6of36
Michigan
I don't have one, but I believe I read a post about calibrating sensors, to level side to side. If you can do that, I don't see why you cant adjust both on the same side. Someone who knows should chime in to confirm, but like I said, I think I read that. It's probably easier to change the links though, because when I read it, it seemed pretty hit and miss until you get the digital setting right.
